Step 7 Pump off command delay issue
larry
I've been struggling with the problem for a long time and need everyone's help, thank you
If the pump is stopped after a certain delay in working mode or standby mode, why should the subsequent program delay a cycle to generate the pump command? This command is located in Network 6
I took a closer look at the process and guessed that this waiting for a cycle problem should have nothing to do with the process running?
My glass ball says 42.
Nah jokes aside. You´re trying do find a reason for the 1 cycle delay? Or what is your problem?
If so i would suggest, no one really cared about 1 plc cycle.
Otherwise, give more info pls : D
Indeed, I thought about it for a long time, the content of the program comment is to wait for a cycle, 0ms,, I guess the author should have written an unwanted program and forgot to delete it, right?
