Actual project on term (FSoE Address = 3):
User: sebseb
Version: 1
Date: Thu Jan 24 10:25:42 2013
CRC: 0x8F42
TwinSAFE Parameter (Summary):
Connections: 2
Groups: 1
Function Blocks: 1
Mapped Outputs: 4
Detailed project configuration:
* TwinSAFE Group 1 (1 FB(s), 2 Connection(s))
RUN/STOP is linked to StandardIn 1.0.
ERR_ACK is linked to StandardIn 1.1.
* TwinSAFE Connection 1 (This term is master.)
Associating term is "EL1904".
FSoE Address of associating term = 2, Connection-Id = 1, Watchdog = 1000 ms, SIL = 2.
Parameter:
Operating Mode (Index #x8000:1) is digital
Sensor test Channel 1 actve (Index #x8001:1) is true
Sensor test Channel 2 active (Index #x8001:2) is true
Sensor test Channel 3 active (Index #x8001:3) is true
Sensor test Channel 4 active (Index #x8001:4) is true
Logic of Channel 1 and 2 (Index #x8002:1) is single logic channel 1/2
Logic of Channel 3 and 4 (Index #x8002:3) is single logic channel 3/4
Store Code (Index #x10E0:1) is 0x0
Project CRC (Index #x10E0:2) is 0x0
* TwinSAFE Connection 2 (This term is master.)
Associating term is "EL2904".
FSoE Address of associating term = 1, Connection-Id = 2, Watchdog = 1000 ms, SIL = 2.
Parameter:
Standard outputs active (Index #x8000:1) is false
Current measurement active (Index #x8000:2) is true
Testing of outputs active (Index #x8000:3) is true
Error acknowledge active (Index #x8000:4) is false
* TwinSAFE Function Block #1 (AND)
AndIn1 (Break Contact) is linked to TwinSAFE Connection 1 (ConnId = 1), Channel 1.
AndIn2 (Break Contact) is linked to TwinSAFE Connection 1 (ConnId = 1), Channel 2.
* Mapped TwinSAFE Outputs
TwinSAFE Group 1, output FB ERR is linked to StandardOut 1.0.
TwinSAFE Group 1, output COM ERR is linked to StandardOut 1.1.
TwinSAFE Group 1, output OUT ERR is linked to StandardOut 1.2.
TwinSAFE Function Block #1, AndOut is linked to TwinSAFE Connection 2 (ConnId = 2), Channel 1.
