public class CodesysV3
private const string NATIVEDLL = "PLCHandler";
[DllImport(NATIVEDLL, CallingConvention = CallingConvention.Cdecl)]
public static extern UIntPtr PLCHandlerInitByFile([In]uint a1, [In]string a2, [In]string a3);//a1 = 0,a2 = ./driver/PLC%x.ini,a3 = ./driver/PLCHandlerDemoC.log
public static extern int PLCHandlerConnect([In,Out]UIntPtr a1, [In]uint a2, [In]UIntPtr a3, [In]int a4);//a2 = 10000,a3 = 0,a4 = 1
public static extern int PLCHandlerGetState([In]UIntPtr a1);
public static extern int PLCHandlerDisconnect([In]UIntPtr a1);
public static extern int PLCHandlerSetFinalShutDown([In]UIntPtr a1);
public static extern int PLCHandlerSyncWriteVarsToPlc([In]UIntPtr a1, [In]string[] a2, [In]uint a3, [In]IntPtr a4);
public static extern int PLCHandlerSyncWriteVarsToPlc2([In]UIntPtr a1, [In]string[] a2, [In]uint a3, [In]IntPtr a4, [In] uint[] a5);
public static extern UIntPtr PLCHandlerSyncReadVarsFromPlc([In]UIntPtr a1, [In]string[] a2, [In]uint a3, [Out] out IntPtr a4, [Out] out uint a5);
public static extern int PLCHandlerSyncReadVarsFromPlcReleaseValues([In]UIntPtr a1,[In] UIntPtr a2);
class Program
static void Main(string[] args)
int res = 0;
UIntPtr ulPLCHandler = CodesysV3.PLCHandlerInitByFile(0, "PLC7f000001.ini", "PLCHandlerDemo.log");
if (ulPLCHandler != UIntPtr.Zero)
res = CodesysV3.PLCHandlerConnect(ulPLCHandler, 0x2710u, UIntPtr.Zero, 1);
if (res != 0)
if (CodesysV3.PLCHandlerGetState(ulPLCHandler) == 2)
Console.WriteLine("**** No symbols on PLC ****");
else
Console.WriteLine("**** No connection to plc ****");
else
Console.WriteLine("PLC connected successfully");
Console.WriteLine("Press any key Write value to PLC");
Console.ReadKey();
string tagName = "Application.GVL.var3";
uint tagCount = 1;
short value = 3000;
byte[] valueByteArray = BitConverter.GetBytes(value)/*new byte[] { value}*//*new byte[4]*/;
//Buffer.BlockCopy(Encoding.ASCII.GetBytes(value), 0, valueByteArray, 0, 2);
IntPtr valuesPtr = Marshal.AllocHGlobal(8);
IntPtr valuePtr = Marshal.AllocHGlobal(valueByteArray.Length);
Marshal.Copy(valueByteArray, 0, valuePtr, valueByteArray.Length);
Marshal.WriteIntPtr(valuesPtr, valuePtr);
uint a5 = (uint)valueByteArray.Length;
res = CodesysV3.PLCHandlerSyncWriteVarsToPlc2(ulPLCHandler, new string[] { tagName }, tagCount, valuesPtr, new uint[] { a5 });
if (res == 0)
Console.WriteLine($"[{DateTime.Now.ToString("yyyy-MM-dd HH:mm:ss.ffff")}] Write value {value} to PLC successfully");
else
Console.WriteLine($"[{DateTime.Now.ToString("yyyy-MM-dd HH:mm:ss.ffff")}] Write value {value} to PLC faild");
Marshal.FreeHGlobal(valuePtr);
Marshal.FreeHGlobal(valuesPtr);
//while (true)
UIntPtr varListHandler = CodesysV3.PLCHandlerSyncReadVarsFromPlc(ulPLCHandler, new string[] { tagName}, tagCount, out IntPtr readValuePtr, out uint ulNumOfValues);
if (varListHandler != UIntPtr.Zero)
byte[] byteArray = new byte[100 + a5];
Marshal.Copy(readValuePtr, byteArray, 0, byteArray.Length);
uint ulTimeStamp = BitConverter.ToUInt32(byteArray, 0);
byte bQuality = byteArray[4];
short shortValue = BitConverter.ToInt16(byteArray, 5);
Console.WriteLine($"[{DateTime.Now.ToString("yyyy-MM-dd HH:mm:ss.ffff")}] ulTimeStamp = {ulTimeStamp} bQuality = {bQuality} shortValue = {shortValue}");
//res = CodesysV3.PLCHandlerSyncReadVarsFromPlcReleaseValues(ulPLCHandler, varListHandler);
Marshal.FreeHGlobal(readValuePtr);
Console.WriteLine("Press any key Disconnect PLC");
Console.ReadKey();
res = CodesysV3.PLCHandlerDisconnect(ulPLCHandler);
res = CodesysV3.PLCHandlerSetFinalShutDown(ulPLCHandler);
Console.WriteLine("Press any key exit app");
Console.ReadKey();
